hi all,
Can anyone explain why the control over brushed metal and sheet metal parts doesnt work? please see attached images. I have tried every type of mapping and rotating, but nothing works. thoughts? Gonna pull whats left of my hair out...
hi all,
well i made a new part just to test, cause i know this has worked fine in the past, and voila! it applies properly.....any idea why this would happen??
Did you apply the appearance to the part folded or flat?
If you applied while it was folded then you'll have to apply it to same direction faces in order to control the mapping like you want.
If you applied it while was flat it should work like your picture shows but I'm guessing when you bend it the mapping will look like your other picture. If the mapping is still correct after bending then I'd be very surprised. If that works though then it's a great tip for appearances on sheetmetal parts.
Tony,
I Have/had the same problem,
If you edit the appearance of the brushed steel, and go to advanced, mapping, towards the center
change the mapping from automatic to surface.
it fixed it on my PC,
Frank
Here are the results. On my original piece no matter what i change the mapping does not display correctly. as soon as i change the base flange to TOP plane, the mapping direction is good.....i wonder what would cause this?? I cant change the plane since all my holes and assembly will go to hell....argh.
Try unchecking 'simplify bends' in Options: Document Properties: Sheet Metal and see if that helps.
