Hi all,
I have a truss consisting of cyllindrical rods. The nodes are currently sharp corners where the cyllinders impinge. I want to smooth out these corner. So for example, I have an equilateral triangle. The edges are made up of cyllinders. There are sphere of radius equal to the cyllinder radius at the corners, so the exterior corners are smooth. I would like to smooth out the interior corners.
Basically i want to do a fillet, but on cyllinders instead of lines.
Any help is greatly appreciated.
Adam
Adam,
You should be able to just pick an edge where two of your rods join and put a Fillet feature on it. If you are generating your truss as a multibody part, you need to join the bodies before you can add the Fillet.
Jerry S.
