Hi:
I want to simlate stresses on a shaft due to rotation. This shaft is supported by two bearing. I am aware that there are two types of bearing support1-connector 2-fixture but I dont know when to use each of them and HOW. I appratiate any comments regarding to HOW to apply these two supports?
Regards
Do you care about the shaft or the bearing or the bearing support?
Is the shaft symmetric about the axis?
What is the loading condition you are concerned with?
The reason I ask is because in simulation the closest thing to a rotational load is centrifugal which applies a body load to the part. This is only appropriate for certain problems. Motion can tell you able imbalances at the restraints when rotated.
