Hi there,
I am thinking of modeling my race car in solid works. I would then also like the ability to use solidworks electrical to:
1. Layout the electrical components in my car model
2. Find the shortest route to wire each wire to minimize weight
3. Provide a finished scematic drawing on how the car is wired
Basically, i realize solidworks elec. will be able to provide me a scematic like I asked. Im just not sure after modelling my race car, if i can incorporate SW Elec into that model so i can see if a wire needs to go over,through frame components etc...If i can layout the wiring in my race car model, after ive made the model and done the wiring in the model, can i still pull a scematic drawing?
Hopefully that explains what im after. Thanks all!
Chris,
Chris,
I think Tony's "modules" are referring to the Schematic software and the Routing Bridge software. The bridge is what I referred to above as the CAD component. It is what creates the handshake between E3 and SW Routing.
The general workflow would be:
You would need to create a library of 2D schematic library components representing all your components. The software comes with basic library you will likely be able to use. The library items would be your lights, connectors, terminals, switches, relays, fuses, and wire.
You would create your 2D schematic placing your components and then drawing your connections. Your connection lines can then have a wire type assigned to them.
Once you have your schematic completed, you would bring this into your SW environment to model the physical routing. I am not sure on the details of this because we do NOT have SW electrical.
We used this for a big project with SW2008 and manually exported/imported between E3 and SW. The libraries in SW and E3 had to match EXACTLY (names, spelling, capitalization, etc) to get it to work. I know Routing has had numerous improvements since then to make this more usable. And the SW Electrical functionality may provide tools to ease this part of it.
The routing assembly would be created as a subassembly in your race car model. SW Electrical should take care of bringing in the components specified in the 2D schematic, but you would need to perform the actual placement. Once the components are mated and the routing designed, the lengths of the individual conductors or wire groups are fed back to the 2D schematic.
The 2D can then create a nail-board drawing for producing the actual harness.
If you have not priced the SW electrical suite yet, be prepared for $3K per module. Might be more. Or there might be some promotional deals.
Daen
