HELP!
I took the routing training last October but have not used the program much since. I downloaded course files and began to go thru the Routing course manual to get familiar again.
I am running into a problem that has me stalled. After I drop a flange and try to start a route the program is not finding the route assembly template.
The template should show up in the white box. See the 2 images below. Including the route settings. Can anyone tell what to do?
Jeff,
This thread will not only explain to you where you should find it normally but also, thanks to Mr. Deepak Gupta , give you the file in case you don't have it as well as explaining how you can make it yourself in case it's the wrong version.
Have a nice one.
