I have an assembly with many parts (over 200). Throughout the tree I have the same parts (gaskets, etc) and they are randomly distributed depending on how I created my assembly model. Id like to have an easy to way to sort or group common parts. Is there a way to do this? I am using Solidworks 2012.
-Nick
Nick,
A couple of tools will help you out.
First off, you can hold down the Alt key and click and drag components to a new location in the feature tree. You can also Ctrl-Select multiple components then use the Alt-Drag method.
You can create folders to group components.
To help speed up working with your 200+ components, use the filter at the top of the assembly tree. Type in gasket and only components containing gasket will be shown. You can then Ctrl-Select / Alt-drag these into the gasket folder.
Daen
