4 Replies Latest reply on Mar 11, 2013 4:40 AM by Chris Day
    Body-Move/Copy VBA Help needed (SelectByID2 with Face?)
    Chris Day
      I'm trying to apply the Move/Copy command on a single-bodied part (attached). I saved my commands with the macro recorder and am trying to edit the code to work generally.
      What I'm having trouble with is selecting the face of the body. I've been fiddling with the code for ages trying various things, but nothing is working. Any help would be appreciated.
      The code below is what I'm working on. It can be pasted into an empty module if neccessary. The first bit of code finds the largest face and I tried to squeeze this in to the Move/Copy code in every way I could imagine but nothing seeems to work. I'm not really sure what the best way forward is.
      Private Sub AfterCreation()
          Dim swBody As SldWorks.Body2
          Dim swFace As SldWorks.Face2
          Dim swEntity As SldWorks.Entity
          Dim swSelData As SldWorks.SelectData
          Dim swModExt As SldWorks.ModelDocExtension
          Dim Faces As Variant
          Dim Body As Variant
          Dim swPart As SldWorks.ModelDoc2
          Dim swComponent As SldWorks.Component2
          Set swModel = swApp.ActiveDoc
          Set swPart = swModel
          Set swModExt = swModel.Extension
          ' Find face with largest surface area to align with front plane
          Dim LargestFaceArea As Double
          Dim CurrentFaceArea As Double
          Body = swPart.GetBodies2(swSolidBody, True)
          swModExt.SelectByID2 Body(0).Name, "SOLIDBODY", 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault
          Set swBody = swSelMgr.GetSelectedObject6(1, -1)
           Set swFace = swBody.GetFirstFace
          Do While Not swFace Is Nothing
              CurrentFaceArea = swFace.GetArea
              If CurrentFaceArea > LargestFaceArea Then
                  LargestFaceArea = CurrentFaceArea
                  swFace.Select (0)
              Set swFace = swFace.GetNextFace
          Loop
          ' Apply Move/Copy feature
          Dim longstatus As Long
          Dim Component As Object
          Dim FeatureData As Object
          Dim varFeature As Object
          swPart.ClearSelection2 True
          swPart.Extension.SelectByID2 Body(0).Name, "SOLIDBODY", 0, 0, 0, False, 1, Nothing, 0
          Set varFeature = swPart.FeatureManager.InsertMoveCopyBody2(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, False, 1)
          Set FeatureData = varFeature.GetDefinition()
          swPart.Extension.SelectByID2 "", "FACE", 0, 0.05, 0.008, False, 1, Nothing, 0 ' <---- MUST BE GENERALISED!!!
          swPart.Extension.SelectByID2 "Front Plane", "PLANE", 0, 0, 0, True, 1, Nothing, 0
          FeatureData.AddMate Nothing, 0, 0, 0, 0, longstatus
          varFeature.ModifyDefinition FeatureData, swPart, Component
        • Re: Body-Move/Copy VBA Help needed (SelectByID2 with Face?)
          Artem Taturevych
          Are you trying to select the face with largest area which you are finding in the snippet before? If so you can just call the Select method just the same as you are doing here:
          swFace.Select (0)
          You just need to store the pointer to the face. Something like that:
          Dim maxFace as SldWorks.Face
                      swFace.Select (0)
                      Set maxFace = swFace
          Loop
          and then select instead of SelectByID2
          maxFace.Select2 False, 1
          Otherwise sorry - I have missed your point.
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Chris Day
              Hi Artem,
              Thanks for your time. That is what I'm looking to do, and your solution is surprisingly simple.
              However, it doesn't seem to work after I've initiated the Move/Copy feature. When the line maxFace.Select2 runs I get an error saying "The object invoked has disconnected from its clients." The line runs fine inside and immediately after the loop, so in itself it's working fine. Once maxFace has been set it reads <No Variables> all the way up to the error, and as far as I can see the Face interface doesn't even have a Select method (although I imagiine it inherits it from a parent?) so I'm not really sure how to debug this. Searching for a solution online also yielded no results.
              Below is the full code I'm using, in case I'm doing something weird. I tried it with both Face and Face2 interfaces with no change in result.
                  Dim Body As Variant
                  ' Reorient to principal views
                  Dim maxFace As SldWorks.Face2
                          swFace.Select (0)
                          maxFace.Select2 False, 1      ' <-- runs fine
                  Loop
                  swModExt.SelectByID2 Body(0).Name, "SOLIDBODY", 0, 0, 0, False, 1, Nothing, 0
                  maxFace.Select2 False, 1  ' <-- object has disconnected
