Re: Automatic Drawing of Mirrored Part
Atindra Singh Mar 7, 2013 6:02 AM (in response to Mike Pres)Hi Mike,
How've you created the miiror part?? 1) as a new part or 2) by creating derived configuration?
To do the above functionality, create mirrored part by using derived configuration.
So what you need to after making drawing is, just to change the configuration of the parent part to mirrored.
Now everything (the dimention & annotations) will remain same.
Try this I hope it will work for you.
Mike Pres Mar 7, 2013 11:55 AM (in response to Atindra Singh)hey Atindra,
the mirrored part was created in an assembly and saved as was suggested to me. it's an automatic part which gets updated automatically everytime i change something in the original. i don't even bother opening the mirror, i have no reason to do it. i think it's neither of what you suggested.
how can i make it a derived configuration? do i need to mirror the part about a surface, without keeping the original, save as a new config. and supress the new feature in the old config.? are you sure SW will able to process that and change all the drawings and measures correctly?
Suraj Sethi Mar 7, 2013 8:35 AM (in response to Mike Pres)Hey Mike,
Have you already created a drawing of the original part?
If so, all you need to do point your drawing to reference the new "mirrored part." You can change the part that your drawing is referencing either by hitting File -> Save as on the drawing and selecting the "References" option at the bottom and browsing for the new part or you can also change the reference by using Solidworks explorer.
Suraj
Mike Pres Mar 7, 2013 11:58 AM (in response to Suraj Sethi)hey Suraj,
yes, the original drawing is complete. are you sure what you suggested works? i think SW gets really confused when you do that (he colors all the old measurments in mustard-color). i'm sure it works when your refering it to a similar part that has same original features, but i haven't tried that with a full mirror.
Suraj Sethi Mar 7, 2013 11:51 PM (in response to Mike Pres)Hey Mike,
Apologies, I just tried it on my end and yes, you're right. Solidworks doesnt like the fact that the internal ID of the component has changed and hence the dimensions become dangling (mustard colour)
I'll see if there is a different workaround
Suraj
Matthew LoronoMar 8, 2013 1:52 PM (in response to Suraj Sethi)
Model item (from the model) dimensions can be used and shouldn't go dangling. In SW2013, it is much easier to bring over dimensions for mirrored components from the original model.
