I'm trying to create a macro that traverses thru the sub assembly and renames the part files using the custom properties associated in that paticular file.
I used the Rename macro that is in the Solidworks API help. My problem is it takes the properties from the main subassembly and not the paticular part file. I'm very green to macro's so any help you can provide would be helpful
thanks
This is what I have so far
Option Explicit
Public Enum swUserPreferenceToggle_e
swExtRefUpdateCompNames = 18
End Enum
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swConfig As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim SwCustProp As SldWorks.CustomPropertyManager
Dim Children As Variant
Dim bOldSetting As Long
Dim swChild As SldWorks.Component2
Dim ChildCount As Integer
Dim DetailNo As String
Dim JobNumber As String
Dim Description As String
Dim NewName As String
bOldSetting = swApp.GetUserPreferenceToggle(swExtRefUpdateCompNames)
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, False
Dim bRet As Boolean
Dim i As Long
Dim DetNumber As String
Set swModel = swApp.ActiveDoc
Set swConfigMgr = swModel.ConfigurationManager
Set swConfig = swConfigMgr.ActiveConfiguration
Set swRootComp = swConfig.GetRootComponent
Children = swRootComp.GetChildren
ChildCount = UBound(Children)
For i = 0 To ChildCount
Set swChild = Children(i)
' Changing component name requires component to be selected
bRet = swChild.Select2(False, 0)
' Get Detail Number from Custom Properties
JobNumber = swModel.CustomInfo("ProjName")
Description = swModel.CustomInfo("Comment")
DetailNo = swModel.CustomInfo("test")
NewName = JobNumber + "Det " + DetailNo + " " + Description
swChild.Name2 = NewName
Next i
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, bOldSetting
