3 Replies Latest reply on Mar 6, 2013 1:21 PM by Valkyrie Savage
    Alternative for Surface2 GetProjectedPointOn ?
    Valkyrie Savage
      I found this KB article : https://customerportal.solidworks.com/eservice_enu/start.swe?SWECmd=InvokeMethod&SWEMethod=GotoRecord&SWEService=SWGotoRecord&ViewName=SW+All+Defects+List+customerportal+-+Search&BusObject=Product+Defect&BusComp=Product+Defect&Id=1-11RDEO9 which seems to indicate that the problem I am having, namely that my addin doesn't seem to have enough memory to run getprojectedpointon for purposes of raytracing, is a problem others have had.  It doesn't sound like it has been resolved, either.
      So what should I use in lieu of getprojectedpointon ?  Is there a face-, surface-, or feature-level function that will do basically the same thing?  I want to do some raycasting/mirror simulation, and I have to figure out where cast rays hit my parts.
      pseudocode:
      for each ray in raySet:
        for each face on body:
          if ray intersects face:
            reflect ray
            if reflectedRay intersects body2:
              insert mirror at ray reflection point on body1
      Any thoughts?
        • Re: Alternative for Surface2 GetProjectedPointOn ?
          Artem Taturevych
          Check this - basically the same thing. Just consider the ray direction and start point as the corresponding point and projection direction.
          IModelDoc2::RayIntersections.
          ModelDoc2::GetRayIntersectionsPoints.
          ModelDoc2::GetRayIntersectionsTopology.
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Valkyrie Savage
              I wish I could give you awesome points for knowing the answers to all my questions!
                Valkyrie Savage
                Are there any examples of this function in use?  I didn't find examples in the documentation, and when I tried to use it, it crashed SolidWorks...  this code has camera.rayVectorOrigins that takes a bunch of MathPoints (about 16) and shoves them into a double[] and camera.rayVectorDirections which does the same thing for MathVectors (also about 16).  I didn't get any error messages, just SolidWorks crashes almost immediately after invoking this function.
                            double[] rayVectorOrigins = camera.rayVectorOrigins();
                            double[] rayVectorDirections = camera.rayVectorDirections();
                            object[] bodies = myComponent.GetBodies2((int)swBodyType_e.swSolidBody);
                            alert("we are trying with component " + myComponent.Name);
                            int numIntersectionsFound = swDoc.RayIntersections(bodies,
        rayVectorOrigins,
        rayVectorDirections,
        (int)(swRayPtsOpts_e.swRayPtsOptsTOPOLS | swRayPtsOpts_e.swRayPtsOptsNORMALS),
        .01,
        .01);
                            if (numIntersectionsFound > 0)
                                double[] horrifyingReturn = swDoc.GetRayIntersectionsPoints();
                                int lengthOfOneReturn = 9;
                                for (int i = 0; i < numIntersectionsFound; i++)
                                    double bodyIndex = horrifyingReturn[i * lengthOfOneReturn + 0];
                                    double rayIndex = horrifyingReturn[i * lengthOfOneReturn + 1];
                                    double intersectionType = horrifyingReturn[i * lengthOfOneReturn + 2];
                                    double x = horrifyingReturn[i * lengthOfOneReturn + 3];
                                    double y = horrifyingReturn[i * lengthOfOneReturn + 4];
                                    double z = horrifyingReturn[i * lengthOfOneReturn + 5];
                                    double nx = horrifyingReturn[i * lengthOfOneReturn + 6];
                                    double ny = horrifyingReturn[i * lengthOfOneReturn + 7];
                                    double nz = horrifyingReturn[i * lengthOfOneReturn + 8];
                                    alert("our entire horrifying return " + bodyIndex + "," + rayIndex + "," + intersectionType + "," + x + "," + y + "," + z + "," + nx + "," + ny + "," + nz);
                                    alert("we hit body " + ((Body2)bodies[(int)bodyIndex]).Name + " at " + x + "," + y + "," + z);
                                    visualizeRay("cameraRay-" + randomString(15), camera.rayVectors().ElementAt((int)rayIndex), camera.rayVectorSources().ElementAt((int)rayIndex));
