I am trying to make this structure using sheets. In the absense of guide curve in the sheetmetal lofted bend option, I had to make it as a part first.
My guide curve is third degree polynomial. Now I can't flatten this using "Convert to sheetmetal" option.
Please help me out.
I also have attached the part in this post.
Thanks in advance.
Create your guide curves so they go corner to corner, either by creating new planes or using 3d sketch. this part would require 4 sheetmetal bodies, so model as seperate bodies. If you create the guide curves on the corners and draw a line top and bottom you could create the parts as sheetmetal lofts.
