Please can somone help or point me in the right direction.
Do you know why I am getting just an on or off it does not fade away in and out in the recorded time line It just switches off no longer on view at the last key.
Fades in and out on the screen when setting it up. But then in the recording it just switches off at the key
NO fade just ON and off All the videos i have seen so far show it fading away.
Tried it with just a simple block in the assembly nothing else start with it visible move the time line down three /four seconds then hide the block it fades away ok But when I look at it with the play it just ON THEN ITS OFF
Thank
Andrew
I just had an e- mail i back from SolidWorks suport today (5th March)
Thanks for providing the RX and other information. This helped me in understanding the issue correctly.
Yes, currently this is a known issue. It has already been reported to development team (SPR 631248: The hidden component did not be hidden gradually when play animation, but hide the component suddenly.) Development team will be working on it as per their priority list.
I am glad that you have already found a workaround to resolve this issue temporarily till development resolves this issue permanently.
Thanks everyone for your help with this thorght it was me at first!
Andrew
Works for me. Can you share your files to check or even sample files.
Also what is your SW version, OS and graphics card details.
