What I'm trying to do is have a belt/ chain wrap 360 degrees or less around a egg shape or offset hole cam and when pulled in a linear direction from the end of the belt/ chain it will straighten out, such a connecting it to a hydraulic cylinder.
I can get it to work with a cam that has a single radius only.
Thanks for any help P.S. I'm using SW08
Updated with model:
When the violet shaft is moved down i would like the green sprocket/ cam to spin, i just cant figure out what mates that will allow he chain to follow the sprocket on a tangent but also be parallel to the violet shaft.
I need this to do a cosmosxpress study on the hydraulic cylinder
Reno,
I didn't look at your files, but you might try using the Fit Spline to replace the sketch elements that form your egg shape. That way it ends up being spline instead of multiple arcs.
Jerry S.
