Is there a limit on the number of characters that can be input as a variable's value? I currently have variable linking to certain cells in an Excel form. However, when the cell's character counts exceeds 255, the variable linking no longer works (shows the cell name in the data card intead of the cell value). I'm not sure if this is a limitation with Excel or PDM, but in either case, does anyone have suggestions for how to get around this?
Sally
Sally,
This is a limitation for custom properties in any MS Office format. It's not an EPDM limitation, if you open an excel file outside the vault, go to File->Info and select the Advanced Properties you can insert your own custom property and you will run into the same limit.
