4 Replies Latest reply on Mar 1, 2013 3:12 AM by Unspecified Unspecified
    New to Draftsight
      I have recently downloaded draftsight to edit dwg drawings. Just as a trial i save a solidworks drawing as a DWG drawing. I can open it in draftsight but am having dificulty in figuring out the dimensions. When drawing in solidworks i used millimetres, but if i put a dimension on a line it assumes it is metres, and converts it to millimetre, eg if i have a line of known length 90mm, Draftsight takes it as being 90metres and hence displays it as 90000. I have used autocad in the past,and could use it to a reasonable extent. But havent used it now though in about 4 years so have forgot most of what i knew.
      So would any one have a solution to my problem, how can i get it put 90mm on instead of 90000.
      Regards
      Mike
