After updating to SolidWorks 2013 and consequently VBA 7.1 some lines of code that were previously functional now result in errors. Most of them were related to keeping UserForms on top of other windows so are now obsolete, but the declaration below is critical for other functionality.
Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (pDst As Any, pSrc As Any, ByVal ByteLen As Long)
Does anyone know a fix for this? I wasn't able to add a reference to kernel32.dll, I guess because 32-bit systems are no longer supported, but how do I use this RtlMoveMemory function? If it helps, its alias is used as below.
Public Function ArrayIsInitialized(arr) As Boolean
Dim memVal As Long
CopyMemory memVal, ByVal VarPtr(arr) + 8, ByVal 4 'get pointer to array
CopyMemory memVal, ByVal memVal, ByVal 4 'see if it points to an address...
ArrayIsInitialized = (memVal <> 0) '...if it does, array is intialized
End Function
Thanks.
