I'm conducting an optimization for the attached loaded beam. The profile of the loaded beam is defined via an equation. I'm trying to control the heigh of the beam by adding a dimension sensor and placing a "is less than" constraint on the dimension sensor. For some reason the constraint shows up as having units `lb'. Does anyone know why this is happening and how I might constrain this thickness succesfully?
Thanks!
Hi Jospeh,
You can resolve this issue by measuring the distance between the two end-vertices rather than the length of the line. Give it a try and run the simulation and your issue should be resolved.
