The best way I've found to add o-lets to a piping route involves mating the axis of the o-let to the sketch line of the route. However, when I set sketch entites to visible from the top toolbar, it only shows me parts of the route sketch. If I start a fresh new route assembly, my method works just fine, but for some reason with this assembly, it is not working properly. Anyone know what might be going on?
See attached for illustration of problem.
I had one more thought. You didn't happen to accidentally hide your route sketch did you? I was able to re-create what you showed by hiding my route 3DSketch1 but have the ElbowArc sketch showing on the elbow part level.
