I'm working with Solidworks 2013. I've created a profile and properly uploaded it to the directory as a library feature. I've used weldments before and have never had this problem. As you can see with the attached picture, when I select the line to create the member I encounter an issue with the member offsetting from the line. What's even weirder is that when I repeat the function, the member will offset to a different random distance/direction every time. Anybody have any ideas?
EDIT: I have also drawn the cross section sketch on the front plane, centered on the axis.
Is there any chance that you could upload your profile and the part in the above picture?
It would make it much easier to see what is wrong. I suspect it is the profile but I cannot be sure from just the picture.
Justin
