So I have 6 springs, 6 dampers and 1 force on a shaft. Three spring and dampers on each end of the shaft with 120 degrees between each spring and the springs perpindicual to the shaft. I have a force acting on the shaft acting in the down direction for 0.5 seconds. The springs should be strong enough to prevent the shaft from goin more than 1 inch in any direction, but the shaft goes down and never stops. I have attached the necessary files and was wondering if anyone could figure out what is wrong?
Instead of letting the force definition segments set the force to zero, just turn it off at 0.5 seconds and the problem will solve correctly.
