in 3D Via animation i want to bend the rubber gasket like shown in the pic.....
Initially the gasket is in the below mentioned position:--
After some time the position is:---
any tips , link or workaround to do like this.....
Thanks in ADV
Parthi
Parthi, Have a look at this video http://www.3dmojo.com/2012/09/06/todcast-10-faking-geometry-deformations-tips-and-tricks/. I would apply a similar approach to this gasket. Create a series of deformation configurations of the gasket. From there use File|Open with the "Merge into new document" option selected for the top level assembly. Then use File|Open with "Merge into current document" selected for each of the separate gasket configurations. This will allow you to show|hide these models separately and equally update the assembly at a later date.
-Earl
