1 Reply Latest reply on Feb 25, 2013 10:33 PM by Henry Kurniadi
    Wind turbine blade FEA simulation tutorials
    Bryan Chua
      Hi guys, I had some troubles in analysing loads caused by aerodynamics, gravity and centrifugal force onto the blades. Is there any tutorials or information to work out the force applied on each element? Currently I had finished my NREL 5MW blade modelling and on progression to stress analysis.
      Thanks for your time.
        • Re: Wind turbine blade FEA simulation tutorials
          Henry Kurniadi
          Generally wind turbine design should conform to either IEC 61400-1 (for large wind turbine), -2 (for small wind turbines) or -3 (for offshore wind turbine).
          Special for IEC 61400-2 (for small wind turbines), there is a concept called Simple Load Method.
          The stress analysis should be done in these scenarios.
          Load Case A: Fatigue during Operation (assuming turbine rotate in fluctuation between 2xdesign rpm and 0.5x design rpm for 20 years)
          You need a fatigue analysis for this.
          Load Case B: Yaw
          Load Case C: Yaw error
          Load case D: Max Thrust
          Load Case E: Max Rotation (turbine rotates at 2x design rpm)
          Load Case F: Shorted condition
          Load CAse G: Braking shutdown
          Load Case H: Survival wind (rotor did not rotates, but exposed to extreme wind)
          Load Case I:
          Load Case J: Assembly load.
          Basically you need to calculate each load magnitude (forces and moments) for (at least) blade and shaft.
          Details of equations should be consulted in the aforementioned standard.
          You need to input these loads to each component in SolidWorks Simulation.
