Dear all,
I am still not good at SW. I tried very hard to put the screw assembly (screw and split washer) into a hole on plate as attached here, but still couldn't make it. Can you anyone out there give me some hints on types of mates that I need to create to insert the screw assembly into the hole?
Thank you so much for help in advance.
Kent,
I would go to VIEW >TEMPORARY AXES.
This should show the Centerline ofr the Hole and the Screw. Hold down the CRTL key and Click on both lines and then click the Parperclip Icon (Mates). Choose COINCIDENT. This should center the Screw on the Hole.
Choose the Face of the Panel, and the Face of the Washer in the Same manner, and click the Paperclip Icon (Mates) and choose COINCIDENT again.
Hope this is of use to you,
Regards,
Alan
