When I start a project, I just name a part by its description and won't assign a part number until the part is ready to release.
What's the best way to do this in workgroup PDM - Does rename in Vault work? if I keep doing this, I'm afraid I have to delete many parts in Vaut soon they're ready to release and I don't think it's a good practive on Vault???
Chris,
You can rename items in the vault.
That said, I'll through in my 2 cents worth of suggestion based on working through the same learning curve.
I think you will be much better off naming the part / assembly files by Part Number from the start. This means issuing a P/N for each new file at creation. And it means some part numbers get tossed for items that do not make it into the latter stages of design.
Yes that is a bit of an inconvenience.
Yes you will have missing part numbers.
Yes, it takes some extra time at the beginning.
YES it will save you incredibly significant amounts of time when you don't have to rename items in the vault.
(When you rename in the vault, all local files will loose their link to the vault files - unless you identically rename them)
(Because of this, the best is to ensure all users have deleted all local files and then reload the renamed files from the vault)
YES it will save you incredibly significant amounts of time when you have two "descriptive" named files with the SAME name checked into the vault and the latter overwrites the former.
YES it will save you significant amounts of hair pulling when the boss likes version x and says "make it so" and you reply "we'll have that to the prototype shop in a couple of days because we have to rename our files..."
If you maintain good file house keeping on your local machine, you can name files by description and then perform a SW rename function and assign Part Numbers when the files are checked into the vault for the first time. But this only puts off the inevitable. The least amount of work is to just name them from the start and eliminate the entire rename process.
In the simplest scenario, create a network shared spreadsheet to record part numbers. When someone makes a new part, open the spreadsheet, type in the description and next part number. This has lots of opportunity for conflicts, but it can be workable.
The next step up would be an Access database that will issue the next available part number.
Daen
