Hi all,
I have a multiline variable that is entered in the file card as an edit box. This is transferred to the drawing and creates a multiline custom property in a general table that I am using as a revision table. This works great with the height of the row changing automatically to match what is entered in the edit box. What I would like to be able to do is move the text to the next row up when the drawing is revised, this I have done by shifting the variable during the revise transition. Only problem however is that the multilne text is changed to a single line with <br> where the carrage returns were. Does any one know of a way to revert this to multiline text.
Kerry
Hello Kerry,
If i understand you correctly, You are trying to shift the varible value from one row above on every revision ?
Can you please post some picture of how the result is currently being displayed ?
Regards,
Raghav.
