Saludos,
I have a problem with my simulation Standings and is giving me a negative volume Flow rate
Does anyone know why this happens?
thanks
Fernando Bernal
Saludos,
thanks
Fernando Bernal
thanks for reply, the problem was with a goal GG Mass Flow Rate, which stopped the simulation at a very small value of airflow
Muchas gracias y saludos
Fernando Bernal
Hello
I was also searching for answer on this topic. I agree to disagree with Jared.
After testing Jared answer
"into the computational domain = positive"
"out of the computional domain = negative"
I understand now that this is not true! Because either you look for results in computational domain or not, mass flow is always negative. You can test this easily, just extend computational domain and re-run simulation.
I found in SolidWorks knowledge base 100% accurate answer:
S-022094
"Mass entering a system is positive and mass leaving a system is negative."
(System, not computational domain!)
Regards,
Ivan
