2 Replies Latest reply on Feb 25, 2013 12:33 AM by Jerry Steiger
    Best way to change shape of a 2-part car model connected by screws
    hajime hajime
      Hello, I obtained a model car made of two parts. The upper and lower parts are connected by screws. There are four holes on the upper cover of the car. The screws go through the holes to connect the lower half. In case I want to change the shape of the upper part of the card, what is the best way to do so? There are two scenarios. The first one is to somehow modify the shape of the existing upper case. The second one is to merge another model on the existing upper case. That way, I keep the difficult-to-make shape from the new model while using the existing holes from the original upper case. Any good sources on how to do the two scenarios? Thank you.
