Hi
Is there any way for finding out extra/repeating mates in an assembly using a macro or any kind of setting.
Thanks in Advance,
Arun
Hi
Thanks in Advance,
Arun
Here is the first version. It has performance issue which I'm trying to bypass somehow.
__________________________
Regards,
Artem Taturevych
Application Engineer at Intercad
Tel: +61 2 9454 4444
Hi Artem,
Thanks for the tool.
Should we integrate the tool with SW or how does it work?
It is not asking for adding the asembly or browse to the specific folder.Can you clarify it?
Thank You in Advance
Regards
Arun
This is the performance issue I'm working on. Try to run it on small assembly (say 5-10 mates) just for test.
Hi Artem,
Hope you're doing good.
I tried the .exe for checking the redudnant mates in assembly. it's taking time.
Have you checked anything else on that.
Tnx in Advance
Arun
Hi Arun,
I’m sorry, I forget about this one. Will return to this when I have a time.
____________________________________________________
Regards,
Artem Taturevych, Application Engineer at Intercad (Australia)
translationXpert – add-in to translate SolidWorks models
I have this tool. I need some time to complete this. I will post it here.
Regards,
Artem Taturevych
http://intercad.com.au/
