2 Replies Latest reply on Feb 15, 2013 6:36 PM by Tom Cote
    Get Sheet scale for multiple sheet drawings
    Tom Cote
      Hi guys,
      I'm trying to get the scale of each sheet of a drawing as I loop through them.
      Basically the code from the API help (shown below) will get the scale of the current sheet.  I am doing some tasks to each sheet by using a loop command:
      For i =0 to sheet count -1 and the NEXT command at the end.
      Everything seens to work fine except that the scale does not update per sheet and uses the scale for the sheet that was active when I started the macro.  So if sheet 2 was active and the scale of that sheet is 1:2 but the other sheets 1 & 3 have a sheet scale of 1:1 then it will stay at 1:2 becasue that was active when I started the macro.
      Anybody have any ideas?
      Thanks in advance.
      Tom
      ' Postconditions: Drawing scale set to decimal.
      Option Explicit
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swDraw                      As SldWorks.DrawingDoc
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim swView                      As SldWorks.View
          Dim vScaleRatio                 As Variant
          Dim bRet                        As Boolean
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          Set swView = swSelMgr.GetSelectedObject5(1)
          vScaleRatio = swView.ScaleRatio
          Debug.Print "File = " & swModel.GetPathName
          Debug.Print "  View = " & swView.Name
          Debug.Print "    UseSheetScale  = " & CBool(swView.UseSheetScale)
          Debug.Print "    Scale          = " & vScaleRatio(0) & ":" & vScaleRatio(1)
          Debug.Print "                   = " & swView.ScaleDecimal
          ' Changing scale sets View::UseSheetScale to FALSE
          swView.ScaleDecimal = swView.ScaleDecimal * 2#
          ' Rebuild to see new scale
          bRet = swModel.EditRebuild3: Debug.Assert bRet
