1 Reply Latest reply on Feb 15, 2013 6:23 PM by Artem Taturevych
    select dimension by mouse
    Shousheng Wang
      I want to make program by add dimension special tolerance from comany database. so I want pick up the dimension from drawing and add this dimension into text box in a small form, after that,select tolreance by this dimension from database,then add to solidwork drawing. however, I do not how to pick up dimension from drawing. I use C# toprogram.
        • Re: select dimension by mouse
          Artem Taturevych
          I would implement something like selection box in SolidWorks property manager pages. Either listen for a DDrawingDocEvents_NewSelectionNotifyEventHandler to monitor all the selection or just use the update button on your form to load the currently selected dimension on-demand. Then just call the SelectionMgr::GetSelectedObject6 and you will get the pointer to IDisplayDimension Interface. Now you can work with it: change properties, extract values, names etc.
          Artem Taturevych
          Application Engineer at Intercad
          Tel: +61 2 9454 4444
