I work exclusively in the sheet metal industry. Many times, when I make a part, I have to check and record the bend lengths. At this point, I skect lines from the side and measure them. Is there any way in soldiwrosk to see those Intersections without drawing extra lines?
While in the sketch or drawing mode, select the two line or edges and then click on point. This will create a a point the intersection which you can use for measurement.
