Hello all,
I know that this discussion has been made before, but I am unable to locate it. We are getting ready to to go from SW 2012 SP3.0 to SW 2013 SP 2.0, and I need to know if I need to update WPDM to 2013. And if so, does anyone have a reference guide on how to successfully perform this. I have done plenty of SW updates but never done a WPDM update. I'd appreciate any and all assistance on this.
Steve Zema
Yes you will need to update WPDM. If you are using the SW Install manager, just select "server products" when asked what you are looking to update. Choose the server and it should go just fine. Just be sure the install manager is referencing the correct wpdm location.
You don't need to update the files in the vault but if you choose to, SW Task Scheduler has a task to do it. I would suggest copying your existing vault before doing anything. This is pretty easy - shut off the vault server in "services" on the computer/server where the vault is installed, then simply copy the vault folder to another with a different name in case you need to use it later. Then remember to start the vault service back up.
