Is there a way to create a feature (in this case a set of holes using Hole Wizard) that is done at the "assembled" level of a weldment. My example is that I've got two "legs" on one side of my design that are wide flanges and show up as one item in the cut list. I want to drill a few holes in one of the legs but keep it as a common item to the other one. I know I could create an assembly and do the hole feature there but that wouldn't work with the drawing I'm creating. These two legs are one item before the hole feature and I just need a way to combine them again even though one of them has holes in it.
Thanks in advance
Is this where as-machined and as-welded configurations apply?
The as-machined configuration has the holes un-supressed and the as-welded has the holes suppressed.
The as-welded configuration is the one used in the cutlist and will group all the like members.
Roy.
