Hello;
I have a situation, where I have a bracket that was made from the sheet metal source. I then made the bracket into a weldment, because i needed to add two nuts
to be welded to the bracket. When I go to the drawing, the weld nuts aren't showing up in the cutlist. I know sometimes you have to go back to the model, & the right click
the components, and in the properties, re-apply the properties. like part no. & description. The problem is that the properties comes up with the bracket, but the properties, is n't popping up with the nuts. Any Ideas?
Thks, in advance
Rob_D SW 2012 sp4
I don't make any weldments though I guess it's much the same as a part being converted to an assembly. It may be that your referenced view is to the part (pre-weldment) and not the assembly.
A few years back I was shown that it makes a lot of sense that all parts be saved as assemblies and the assembly, even though it is really a part be shown on the drawing. In my case it wasn't uncommon to add a PEM nut later and the print would open exactly as you descibe.
That advice may not aply to you but I would assume it's worth some consideration. If you would report back whether right or wrong then two of us would learn something.
