I have a sketch of a ventilator: then i used 3d sketch to
make some sort of a triangle with base consisting of three points
and one point on top - now i try to cut it out but nothing works
unless i build 4th point at base and use Extract Cut - but that
poses big problems for me because the fourth point has to be on teh
same plane as other three points and its a lot of work plus i have
to cut out 20 triangles like this and all identical. Please help!
Little question: is it possible to select 20+ figures in 3d
regime and cut them all at once because i wnat this action to be
registered as one action in the Tree of Feauture Management for
easy correction for the feauture (p.s. Linear massive won't work
because all triangles are at different positions in xyz.
Little question: is it possible to select 20+ figures in 3d regime and cut them all at once because i wnat this action to be registered as one action in the Tree of Feauture Management for easy correction for the feauture (p.s. Linear massive won't work because all triangles are at different positions in xyz.
