6 Replies Latest reply on Feb 15, 2013 6:17 PM by Artem Taturevych
    Does anybody know how to acces ConfigurationSpecificCustomProperties with the DocumentManagerAPI ?
    Checkcheck Master
      Hi there !
      Does anybody know how to access ConfigurationSpecificCustomProperties with the DocumentManagerAPI ?
      Greetings !
        • Re: Does anybody know how to acces ConfigurationSpecificCustomProperties with the DocumentManagerAPI ?
          Artem Taturevych
          Use these methods:
          SwDMConfiguration::GetCustomPropertyNames.
          SwDMConfiguration::AddCustomProperty.
          SwDMConfiguration::GetCustomPropertyCount.
          SwDMConfiguration::GetCustomProperty.
          where the SwDMConfiguration retrieved from ISwDMDocument::ConfigurationManager->ISwDMConfigurationMgr::GetConfigurationByName
          Check this example which shows how to traverse configurations and custom properties via DM API:
          http://help.solidworks.com/2012/English/api/swdocmgrapi/get_configuration_information_example_vbnet.htm
          __________________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Checkcheck Master
              Thanks Artem for your reaction,
              I can't get it running to retrieve the ConfigSpecificCustomProperties.
              Tried a lot of things but don't get it...
              Can you please explain me how to set up this in VBA code ?
              Thanks in advance.
              Greetings !
                  Artem Taturevych
                  Here is the vba code. You should add the reference to DM dll to your macro (SwDocumentMgr <Version> Type Library)
                      Const sLicenseKey As String = "<YOUR KEY>" 'Specify license key
                      Const sDocFileName As String = "C:\Part1.sldprt"  'Specify document
                      Dim swClassFact As SwDMClassFactory
                      Dim swDocMgr As SwDMApplication3
                      Dim swDoc As SwDMDocument15
                      Dim swCfgMgr As SwDMConfigurationMgr
                      Dim vCfgNameArr As Variant
                      Dim vCfgName As String
                      Dim swCfg As SwDMConfiguration13
                      Dim nDocType As Long
                      Dim nRetVal As Long
                      ' Determine type of SolidWorks file based on file extension
                      If InStr(LCase(sDocFileName), "sldprt") > 0 Then
                          nDocType = SwDmDocumentType.swDmDocumentPart
                      ElseIf InStr(LCase(sDocFileName), "sldasm") > 0 Then
                          nDocType = SwDmDocumentType.swDmDocumentAssembly
                      ElseIf InStr(LCase(sDocFileName), "slddrw") > 0 Then
                          nDocType = SwDmDocumentType.swDmDocumentDrawing
                      Else
                      ' Not a SolidWorks file
                          nDocType = SwDmDocumentType.swDmDocumentUnknown
                          ' So cannot open
                          Exit Sub
                      If (nDocType <> SwDmDocumentType.swDmDocumentDrawing) Then
                          Set swClassFact = CreateObject("SwDocumentMgr.SwDMClassFactory")
                          Set swDocMgr = swClassFact.GetApplication(sLicenseKey)
                          Set swDoc = swDocMgr.GetDocument(sDocFileName, nDocType, False, nRetVal)
                          Set swCfgMgr = swDoc.ConfigurationManager
                          vCfgNameArr = swCfgMgr.GetConfigurationNames
                          Dim i As Integer
                          For i = 0 To UBound(vCfgNameArr)
                              vCfgName = vCfgNameArr(i)
                              Set swCfg = swCfgMgr.GetConfigurationByName(vCfgName)
                              ProcessConfigCustomProperties swCfg
                          Next
                          swDoc.CloseDoc
                  Sub ProcessConfigCustomProperties(ByVal swCfg As SwDMConfiguration13)
                      Dim vCustPropNameArr As Variant
                      Dim vCustPropName As String
                      Dim sCustPropStr As String
                      Dim nPropType As Long
                      vCustPropNameArr = swCfg.GetCustomPropertyNames
                      Debug.Print swCfg.Name2
                      If IsEmpty(vCustPropNameArr) Then Exit Sub
                          Dim i As Integer
                          For i = 0 To UBound(vCustPropNameArr)
                              vCustPropName = vCustPropNameArr(i)
                              sCustPropStr = swCfg.GetCustomProperty(vCustPropName, nPropType)
                              Debug.Print ("-" & vCustPropName & " <" & nPropType & "> = " & sCustPropStr)
                          Next
                          Debug.Print ("")
