SQL Question from a SQL Noob...
Question asked by Brian Dalton on Feb 8, 2013
Latest reply on Feb 12, 2013 by Shawn Kelly
I'm getting my feet wet on using SQL to query the PDM database, and I need to get a list of files and several of the variables attached to them.  My code works fine on those files where each of the required variables actually exists, but there are a number of older files which were created before some of these variables were implemented, so these older files have no value at all for particular variables.
I'd like them to show up but with that space just left empty, instead the records with missing variables just don't get included in the query results.  I'm a ham-fisted noob on this stuff, so please don't laugh (well, OK. Go ahead) at my clumsy code.  Could someone explain to me how to fix it so I can still get records where some of the fields have no values?
Here goes...
SELECT XD.Filename AS 'Component', VVRev.ValueText AS 'Rev', VVDesc.ValueText AS 'Description',
   X.RefCount AS 'Qty', VVVend.ValueText AS 'Vendor', VVVNum.ValueText AS 'Vendor P/N'
FROM XRefs X, Documents D, Documents XD, VariableValue VVRev, VariableValue VVDesc,
   VariableValue VVVend, VariableValue VVVNum
WHERE D.DocumentID = 76503 AND
      X.DocumentID = D.DocumentID AND
      X.RevNr = D.LatestRevisionNo AND
      XD.DocumentID = X.XRefDocument AND
      VVRev.DocumentID = XD.DocumentID AND
      VVRev.VariableID = 46 AND --Revision
      VVRev.RevisionNo = (SELECT MAX(VVR1.RevisionNo)
                          FROM VariableValue VVR1
                          WHERE VVR1.DocumentID = XD.DocumentID AND
                                VVR1.VariableID = VVRev.VariableID) AND
      VVRev.ConfigurationID = (SELECT MAX(VVR2.ConfigurationID)
                               FROM VariableValue VVR2
                               WHERE VVR2.DocumentID = XD.DocumentID AND
                                     VVR2.VariableID = VVRev.VariableID AND
                                     VVR2.RevisionNo = VVRev.RevisionNo) AND
      VVDesc.DocumentID = XD.DocumentID AND
      VVDesc.VariableID = 45 AND --Description
      VVDesc.RevisionNo = (SELECT MAX(VVD1.RevisionNo)
                           FROM VariableValue VVD1
                           WHERE VVD1.DocumentID = XD.DocumentID AND
                                 VVD1.VariableID = VVDesc.VariableID) AND
      VVDesc.ConfigurationID = (SELECT MAX(VVD2.ConfigurationID)
                               FROM VariableValue VVD2
                               WHERE VVD2.DocumentID = XD.DocumentID AND
                                     VVD2.VariableID = VVDesc.VariableID AND
                                     VVD2.RevisionNo = VVDesc.RevisionNo) AND
      VVVend.DocumentID = XD.DocumentID AND
      VVVend.VariableID = 49 AND --Vendor
      VVVend.RevisionNo = (SELECT MAX(VVV1.RevisionNo)
                           FROM VariableValue VVV1
                           WHERE VVV1.DocumentID = XD.DocumentID AND
                                 VVV1.VariableID = VVVend.VariableID) AND
      VVVend.ConfigurationID = (SELECT MAX(VVV2.ConfigurationID)
                               FROM VariableValue VVV2
                               WHERE VVV2.DocumentID = XD.DocumentID AND
                                     VVV2.VariableID = VVVend.VariableID AND
                                     VVV2.RevisionNo = VVVend.RevisionNo) AND
      VVVNum.DocumentID = XD.DocumentID AND
      VVVNum.VariableID = 56 AND --Vendor P/N
      VVVNum.RevisionNo = (SELECT MAX(VVVN1.RevisionNo)
                           FROM VariableValue VVVN1
                           WHERE VVVN1.DocumentID = XD.DocumentID AND
                                 VVVN1.VariableID = VVVNum.VariableID) AND
      VVVNum.ConfigurationID = (SELECT MAX(VVVN2.ConfigurationID)
                               FROM VariableValue VVVN2
                               WHERE VVVN2.DocumentID = XD.DocumentID AND
                                     VVVN2.VariableID = VVVNum.VariableID AND
                                     VVVN2.RevisionNo = VVVNum.RevisionNo)
See, I told you I was a noob
