"Print range" default
Question asked by Mike Lydon on Feb 7, 2013
Typically my drawings contain several to many sheets (25 or more). Often, when I am editing a part, I need to check the drawing. I am a paper guy. My brain does not see detail well on a monitor, so, I print the sheet. BUT....the default "Print range" is set to "All sheets", when I usually want to print "Current sheet". So what happens is, immediately after hitting print, I realize the "Print range" was set to All sheets", so I have to cancel the print job. This usually results in at least two useless pieces of paper spitting out of the printer. Is there any way to have the default "Print range" setting set to "Current sheet"??? SWX2013 sp1.0
Mike Lydon
