I am trying to control parts' design table from assembly design table and equations. When i create some equations, i manage to change dimensional values of the parts.. (Example: in the equations if i define a formulas like "D2@Sketch2@prova.Part"="1000" , it changes automaticly the value of the design table)
My question if it is possible to change also state of a cut operation? ("Suppress" or "unsuppress") The cut operation that i wanted to disable is: $State@Cut-Extrude1 ... Name of the part is "Prova.part"...
I don't think it is possible to link that from the assembly level.
What you can do is create configurations in your Prova.part with the features supressed/un-supresssed as desired.
Then in the assembly, just set the configuration in your design table using $CONFIGURATION@PROVA
