Hole Wizard - Re Orient Annotation View
Question asked by Jamie Harrod on Feb 6, 2013
I'm trying to reorient the position of the hole wizard Dimensions. Can't find a way to do this.
If I select one of the dimensions and try to "Change Annotation View" it sticks to the right plane. I'm trying to get them onto the front plane, and they will not go no matter what I do!
The only dimension I can change is the poitional dimension which comes in from the 3d Sketch.
Normally, I would just change the sketch plane, but you can't do that on a Hole Wizard Hole.
I know I could create my own hole sketch and revolve-cut. I could also put the details in a parent sketch and use an equation to bind this. But I'm not interested in having to do that either.
Is there another way I should be doing this?
