7 Replies Latest reply on Dec 5, 2016 4:13 AM by Artem Taturevych
    Autosize Refplanes
    Jacob Filek
      I would like to know if anyone can help me.
      I'm trying to create a macro to "Autosize" the first three planes in a part.
      It's a very frustrating problem when I see many part models created by other users that do not autosize the planes.
      In the API there is a IRefPlaneFeatureData.AutoSize() Property that accepts a true or false.
      The problem is that it does nothing. It doesn't matter what version the part was created either pre 2009 or post 2010.
      Here is my code...
      Do While Not Feat Is Nothing
      If Feat.GetTypeName.ToString = "RefPlane" Then
      Dim  finfo As SldWorks.RefPlaneFeatureData
      finfo = Feat.GetDefinition
      If finfo IsNot Nothing Then
      finfo.AutoSize = True
      Loop
        • Re: Autosize Refplanes
          Keith Rice
          This is because you are not modifying the feature definition. After calling AutoSize you need to use IFeature::ModifyDefinition and pass in the IRefPlaneFeatureData object. If this doesn't work either then you may need to use IRefPlaneFeatureData::AccessSelections immediately after using IFeature::GetDefinition.
          Keith
          Video Tutorials for the SolidWorks API
              Jacob Filek
              Thanks Keith,
              I updated my code...
              swModel = swApp.ActiveDoc
                        Dim finfo as SldWorks.RefPlaneFeatureData
                        finfo.AccessSelections(swModel, Nothing)
                        Feat.ModifyDefinition(finfo, swModel, Nothing)
              Feat = Feat.GetNextFeature
              Loop
              Still Nothing Happens!
                  Jacob Filek
                  In the IRefPlaneFetureData Interface Remarks:
                  Before calling any of the methods and properties on this interface, you should determine the reference plane's type because some IRefPlaneFeatureData methods and properties only work with constraint-based reference planes and some only work with non-constrained reference planes. Use IRefPlaneFeatureData::Type2 to determine the type of reference plane.
                  If IRefPlaneFeatureData::Type2 returns swRefPlaneConstraintBase, then the reference plane is constraint based. To determine if a constraint-based reference plane has angle or offset distances references, call IRefPlaneFeatureData::Type:
                  • swRefPlaneAngle is returned for angle references.
                  • swRefPlaneDistance is returned for offset distance references.
                  Otherwise, the reference plane is not constraint based. Call IRefPlaneFeatureData::Type to determine its type.
                  NOTE: Reference planes created in SolidWorks 2010 or later are constraint based; reference planes created in SolidWorks 2009 or earlier are not.
                  The following table shows which IRefPlaneFeatureData methods and properties to use with which types of reference planes.
                  Method or property
                  Constraint-based
                  Constraint-based
                  with angle or offset distance
                  references
                  Not
                  constraint-based
                  AccessSelections
                  GetSelectionsCount
                  IAccessSelections
                  IGetSelections
                  ISetSelections
                  X
                  ReleaseSelectionAccess
                  Angle
                  X
                  AngleOrDistance
                  X
                  AutoSize
                  X
                  Constraint
                  X
                  Distance
                  X
                  OriginOnCurve
                  X
                  ProjectionType
                  X
                  Reference
                  X
                  ReverseDirection
                  X
                  Selections
                  (get only)
                  SolutionIndex
                  X
                  Type
                  X
                  Type2
                  X
                  UseNormalPlane
                  X
                Artem Taturevych
                It is possible to do this via the SolidWorks command. Please find the macro in the attachment which auto sizes all planes and here the VB.NET equivalent for Auto Size first three standard planes. You should add the reference to SolidWorks Commands Type Library in your macro/project.
                Dim Feat As Feature = swApp.IActiveDoc2.FirstFeature
                While Feat.GetTypeName2 <> "OriginProfileFeature"
                      If Feat.GetTypeName = "RefPlane" Then
                            Feat.Select2(False, -1)
                            swApp.RunCommand(swCommands_e.swCommands_Auto_Size, "")
                End While
                swApp.IActiveDoc2.GraphicsRedraw2()
                __________________________
                Regards,
                Artem Taturevych
                Application Engineer at Intercad
                http://intercad.com.au/
                Tel: +61 2 9454 4444
