6 Replies Latest reply on Feb 6, 2013 8:13 PM by Artem Taturevych
    ASSEMBLY CHECK
    Jay Donihoo
      Looking for insight on checking if an assembly is open from drawing, then either opening or switching to the assembly.
        • Re: ASSEMBLY CHECK
          Keith Rice
          Jay,
          If the drawing that references an assembly is open (and the drawing is not a detached drawing) then the assembly is already open. You can use ISldWorks::ActivateDoc3 to activate an already open document.
          For example, if you a single drawing open in SolidWorks (nothing else active, if you go the Windows dropdown), and that drawing references an assembly, this code will activate that assembly:
          Dim vDocs As Variant
          Dim i As Integer
              vDocs = swApp.GetDocuments
              For i = 0 To UBound(vDocs)
                  Set swModel = vDocs(i)
                  If Right(UCase(swModel.GetTitle), 6) = "SLDASM" Then swApp.ActivateDoc3 swModel.GetTitle, True, 1, Empty
              Next i
          Keith
          Video Tutorials for the SolidWorks API
            Artem Taturevych
            Not only the detached drawing but lightweight components are not opened in memory. Furthermore there is no any issue calling the OpenDoc6 prior to activate. If document is loaded just nothing happens otherwise it will be loaded.
            Below is the macro which finds the referenced assembly of drawing rather than any assembly opened in SolidWorks. I'm not sure what exactly you are looking for but Keith's example will activate any assembly opened in SolidWoks without the check whether it is associated with current drawing.
            I would also suggest to use Right function to check the extension rather than InStr. Because if the file name contains SLDASM this will be recognized as assembly (mostly unlikely but still the possibility).
                Set swDraw = swApp.ActiveDoc
                Dim vSheets As Variant
                vSheets = swDraw.GetViews
                Dim i As Integer
                Dim j As Integer
                For i = 0 To UBound(vSheets)
                    Dim vViews As Variant
                    vViews = vSheets(i)
                    For j = 0 To UBound(vViews)
                        Dim swView As SldWorks.View
                        Set swView = vViews(j)
                        Dim modelPath As String
                        modelPath = swView.GetReferencedModelName
                        If LCase(Right(modelPath, 6)) = "sldasm" Then
                            Dim swRefModel As SldWorks.ModelDoc2
                            Set swRefModel = swApp.OpenDoc6(modelPath, swDocumentTypes_e.swDocASSEMBLY, swOpenDocOptions_e.swOpenDocOptions_Silent, "", 0, 0)
            swApp.ActivateDoc3 swRefModel.GetTitle, False, 0, 0
                            End
                    Next
                Next
            __________________________
            Regards,
            Artem Taturevych
            Application Engineer at Intercad
            http://intercad.com.au/
            Tel: +61 2 9454 4444
                Keith Rice
                Thanks for noting that Right() is better than Instr(), though I only presented that code to prove the point that an assembly is already open if a drawing that references it is open. If we're going to write him an error-proof macro, then we should also be using IModelDoc2::GetPathName instead of IModelDoc2::GetTitle, since the latter only returns the extension if "Hide extensions for known file types" is turned off in the Windows folder options.
                Keith
                    Artem Taturevych
                    Keith,
                    I do not say that your macro is incorrect - I just described the difference of my macro and yours and possible 'bottlenecks' in first example. As I said it is not completely clear to me what is requested. Perhaps your macro is exactly what he is looking for, but may be not.
                    ActivateDoc3 will work with the GetTitle regardless this option checked on or off:
                    This will activate the assembly in both cases:
                        Keith Rice
                        I modified my code so that it uses Right() instead of Instr() and also takes into account upper/lower case. Nevertheless it really does not accomplish much at all, it really just proves that ActivateDoc3 will activate an assembly being referenced by an open drawing. Detached and lightweight drawings are exceptions to this, of course.
                        Concerning IModelDoc2::GetTitle... it also has a bottleneck. If multiple documents are open with the same name and "Hide extensions for known file types" is turned on then when used with ActivateDoc3 it can result in the wrong document being activated.
                        Keith
                            Artem Taturevych
                            Keith,
                            Try the following scenario:
                            1) Open any drawing which refers to any assembly
                            2) Open another assembly (not the one which is the reference in the drawing)
                            3) Activate drawing and run your macro. You will see that this will activate both assemblies one-by-one. And the last assembly will be the one from step #2 because it appears later in the documents list but not the one referenced by the drawing.
                            4) Then try my macro - it will activates only the assembly which referenced by the drawing.
                            And this is the main difference between these two macros. The way of activating is not important.
                            Regards,
                            Artem Taturevych
