2 Replies Latest reply on Feb 5, 2013 5:34 PM by Andrew Dvorak
    Property import via XML
    Andrew Dvorak
      Hi all,
      I have successfully imported via XML  a set of property values for a model. However, I was only able to do so when I had the pdmweid set to the DocumentID, which I had to lookup in the vault database tables to get.
      <transaction type="wf_import_document_attributes" date="123456" vaultname="Dane_Test2" ignored="0">
      <document id="" aliasset="" idattribute="" idcfgname="" pdmweid="55514">
      <configuration name="" active="0" quantity="0">
      <attribute name="Number" value="150-040"/>
      <attribute name="Description" value="WCM BASIC CHASSIS"/>
      <attribute name="Revision" value="A"/>
      <attribute name="DrawnBy" value="PDH"/>
      </configuration>
      </document>
      </transaction>
      I would prefer to match the XML transaction sets via Filename, which I have in a list, rather than try to match a DocumentID. Like here:
      <transaction type="wf_import_document_attributes" date="123456" vaultname="Dane_Test2" ignored="0"><document id="150-040_wcm_basic_chassis.sldasm" aliasset="" idattribute="Filename" idcfgname="" pdmweid="">
      but this doesn't work. Is this even possible?
      Thanks in advance.
      Andy Dvorak
