I've tried using the design checker with the task scheduler and it fails.
The task scheduler runs and seems to process the task but it 'fails to save results'. After opening a file and checking it, the file has not been corrected.
(the option to auto correct has been ticked. Permission etc is all correct).
If the same check file is run inside SW the process is completed without error.
Anyone tried this and had success?
(Running SW2012 SP5.0 W7.64bit)
Roy.
Me also have the same problem in (SW2010 SP4.0 XP.64bit.)
solidworks. dont you guys check your product?!
that's make me crazy.
