while making the edge mate between the two circular edges the distance option is not available.WHY???
Not sure of the reason but you can select circular faces to get the distance mate.
no., i have taper faces so thats why i m asking.,
anyhow . i defined the distance by selecting a two plane..........
but my qustion is..
two circular edge mate why the distance option is not avilable??
thnks
Parthi
You can also select their temporary axis.
I'm not sure about the reason of distance mate not available with edges. Please submit a request to your VAR or SW.
ok sir .
can u pls tell me how to submit the request?
thanks
Log into your SolidWorks customer portal account and then click on Enhancement Requests
Good morning Parthiban,
You can select vertex, however you would need to do it multiple times so the parts stay parallel,
Later,
John
