3 Replies Latest reply on Feb 3, 2013 6:12 PM by Artem Taturevych
    How to use Hole table with API?
    Yong Ning
      Hole tables in drawing documents measure the positions of selected holes from a specified origin datum. The software labels each hole with a tag that corresponds to a row in the table.
      At present, the manual methods  select hole .
      Hope select hole with API→Hole table.
      Thanks ever one.
        • Re: How to use Hole table with API?
          Artem Taturevych
          Artem Taturevych
          Application Engineer at Intercad
          Tel: +61 2 9454 4444
              Yong Ning
              Thank your tips
              In Solidworks 2011, run result is
              Dim spec As SldWorks.DocumentSpecification
              'Insert Hole Table Example (VBA)
              'This example shows how to insert a hole table into a drawing.
              ' Preconditions: Ensure that the model and template exist.
              ' Postconditions: A hole table is inserted in a drawing of the model.
              ' NOTE: Because the model is used elsewhere,
              ' do not save changes when closing it.
              Dim Part As SldWorks.ModelDoc2
              Dim Drawing As SldWorks.DrawingDoc
              Dim boolstatus As Boolean
              Option Explicit
              Set spec = swApp.GetOpenDocSpec("install_dir\samples\handson\mate references\crank-arm.sldprt")
              Set Part = swApp.OpenDoc7(spec)
              Set Drawing = swApp.NewDocument("C:\ProgramData\SolidWorks\SolidWorks 2011\templates\Drawing.drwdot", 2, 0.2794, 0.4318)
              Set Part = Drawing
              boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0.39237, 0.5218942019544, 0, False, 0, Nothing, 0)
              boolstatus = Part.Create3rdAngleViews2("install_dir\samples\handson\mate references\crank-arm.sldprt")
              Part.ClearSelection2 True
              boolstatus = Part.ActivateView("Drawing View2")
              'Select a vertex in the drawing view to be the origin of all datums in the table
              'All XLOC and YLOC table column values will be relative to this datum origin
              boolstatus = Part.Extension.SelectByID2("", "VERTEX", 0.05976280781759, 0.2143015374593, 0.003174999999999, False, 1, Nothing, 0)
              'Select a face that contains the holes that will be annotated in the table
              boolstatus = Part.Extension.SelectByID2("", "FACE", 0.1018457263844, 0.2224311921824, 0.003174999999999, True, 2, Nothing, 0)
              Dim myView As Object
              Set myView = Part.SelectionManager.GetSelectedObjectsDrawingView2(1, -1)
              Dim myHoleTable As Object
              'Insert a hole table
              'anchored with its top left corner at x-coordinate = 0.07m and y-coordinate = 0.175m,
              'with starting datum tag "A",
              'using hole table template: standard hole table--letters.sldholtbt
              Set myHoleTable = myView.InsertHoleTable2(False, 0.07841319218241, 0.1755661237785, swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft, "A", "install_dir\lang\english\standard hole table--letters.sldholtbt")
              boolstatus = Part.ActivateSheet("Sheet1")
