Attached is a zero offset from the side of a 1" thick curved panel. I need to flatten it to create a pattern for waterjet cutting. I can hold a piece of tin against this part and trace the edges, and then let it lay flat. But I have tried a zillion different ways to approach this in SW. But I can't get it to convert to a sheet metal part to flatten it. I created a flat section on the end of it to use as the fixed section. I get an error message that the bend line where the curvature starts has a non-linear face. to make sure that the surface isn't cupped or something, I recreated the surface by converting the bottom edge to a 3D sketch, drew a straight line as the vector, and did a vector ruled surface. Same message. But I just know therer's GOT to be a way for SW to flatten this. Thank you anyone that can show me how to flatten this thing into a pattern. - Bob
Please use
1. 3D Sketch (x2)
2. Lofted bends
3. Done!
Example - screen below with SW2013 file
