I would like to export some parts designed in SolidWorks with the file type .dwg or .dxf.
But when I open my part, and I click on save as, these file types doesn't appear in the file types list...
I can only select the following extensions : part (.prt) , Lib Feat Part(.sldlfp) , PartTemplate (.prtdot), eDrawings (.eprt)
I have SolidWorks 2012 Student Design Kit.
Thank you for your answer,
Samuel.
In my 2013 Prem version the dwg & dxf are there so obviously the student version does have a limitation there. I'm not familiar with SV at all but I assume you can make a SW drawing from a part. You might then be able to go to dwg from the drawing file.
