4 Replies Latest reply on Feb 12, 2013 11:01 AM by Patrick O'Hern
    "IF" equation and 1000 Hole pattern
    Michael Maz
      Hi guys, is there an IF equation that would determine the instance of a pattern if it is < or > than a specific amount. For example if the length of a shaft is 7metres then there would be 7 holes, 8m 8 holes etc. However lets say the length is 7.98m the instances would still be 7. Without setting up configurations as this increases the complexity of the assembly.
      Also is there a tip on creating patterns greater than 1000 in the X and Y direction without affecting performance?
      Regards
