2 Replies Latest reply on Jan 31, 2013 4:52 PM by Artem Taturevych
    Close Part and Assembly but not Drawing
    Steven Smith
      I'm looking for a line of vb code that will close the active part or assembly file but keep the active drawing file open.
      Can anybody help?
        • Re: Close Part and Assembly but not Drawing
          Keith Rice
          Steven,
          There is no line of code that will do this exact task. Instead you need to use ISldWorks::CloseDoc to close the particular documents you want. If you are trying to close only documents with a particular name, note that you should include the file extension in the name argument, otherwise this method may close the wrong document if multiple documents have the same name (e.g., "123.SLDPRT" and "123.SLDASM").
          To get the names of the open documents, use ISldWorks::GetDocuments. Here is some code that will close all non-drawing documents:
          Dim vOpenDocs As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              vOpenDocs = swApp.GetDocuments
              For i = 0 To UBound(vOpenDocs)
                  Set swModel = vOpenDocs(i)
                  If swModel.GetType <> swDocDRAWING Then swApp.CloseDoc swModel.GetTitle
              Next i
          Keith
          Video Tutorials for the SolidWorks API
            Artem Taturevych
                If swModel.GetType <> swDocumentTypes_e.swDocDRAWING Then
            __________________________
            Regards,
            Artem Taturevych
            Application Engineer at Intercad
            http://intercad.com.au/
            Tel: +61 2 9454 4444
